Tasmota Power Monitor
Plugin from SimonFair
Overview
Reads Tasmota power devices
tasmotapm-unraid
With this UnRaid plugin you can turn a Tasmota device into an energy monitor for your server.
I got the idea from corsairpsu-unraid, but since I don't have a suitable Corsair PSU, I found an alternative in a Tasmota Power Plug.
Introduction
Before you start, be sure that you protect your Tasmota device against incorrect operation. So that you don't accidentally turn off your server. I solved this for myself with the command: PowerOnState 4 This sets the on / off switch in the WebUI and on the device to always on. Therefore, check what would be best for your device before using it. Have a look at the Tasmota Documentation. Use the plugin and device at your own risk. I will not be responsible for any damage.
I use an Aisirer Power Monitoring Plug (AWP07L) with Tasmota firmware 8.5.1 and this template. {"NAME":"AWP07L","GPIO":[56,255,255,255,255,134,255,255,131,17,132,21,255],"FLAG":0,"BASE":18}
Usage
Plugins > Install Plugin
https://raw.githubusercontent.com/Flippo24/tasmotapm-unraid/main/tasmotapm.plg
Download Statistics
4,082
Total Downloads
25
This Month
68
Avg / Month
Downloads by Month
Loading chart...
Related apps
Explore more like this
Explore all
Details
Repository
https://raw.githubusercontent.com/SimonFair/tasmotapm-unraid/main/tasmotapm.plg
Last Updated2026-10-14
First Seen2023-06-17
