All apps · 0 apps
shoginn-flightradar24
Docker app from FoxxMD's Repository
Overview
Refer to the support thread for instructions on how to setup a dump1090 feed with your radio device.
Note: If you have issues with the docker crashing with default settings set mlat and mlat w/o gps to no. There is a known bug in the current fr24 binary build.
Readme
View on GitHubflightradar24
Docker container for ADS-B - This is the flightradar24.com component
This is part of a suite of applications that can be used if you have a dump1090 compatible device including:
- Any RTLSDR USB device
- Any network AVR or BEAST device
- Any serial AVR or BEAST device
Container Requirements
This is a multi architecture build that supports arm (armhf/arm64) and amd64
You must first have a running setup for before using this container as it will not help you on initial setup
Container Setup
Env variables must be passed to the container containing the flightradar24 required items
Defaults
DUMP1090_SERVER=dump1090 --- default dns name (configurable)
DUMP1090_PORT=30005 -- default port (configurable)
MLAT==yes (configurable)
MLAT_WITHOUT_GPS=yes (configurable)
MPX=no (configurable)
Port 8754/tcp is exposed to show you the status of flightradar (web ui)
User Configured
- FR24FEED_KEY - This is your user specific key
Example docker run
docker run -d \
--restart unless-stopped \
--name='flightradar24' \
-e FR24FEED_KEY="321349dd" \
shoginn/flightradar24:latest
Status
| branch | Status |
| master |
Install shoginn-flightradar24 on Unraid in a few clicks.
Find shoginn-flightradar24 in Community Apps on your Unraid server, review the template, and click Install. Unraid handles the Docker app or plugin setup from the published template.
Categories
Related apps
Explore more like this
Explore allLinks
Details
