MQTT-Camera-AI-Monitor
Docker app from grtgbln's Repository
Monitor MQTT channels for trigger commands, captures high-quality images from RTSP cameras using FFmpeg, and processes them through OpenAI-compatible AI endpoints for analysis.
Requirements
        Expects a "config.yaml" file to be mounted at the Config File path before starting the container. See configuration details: https://github.com/Cossey/mqtt-camera-ai-monitor/blob/main/config.yaml.sample
Overview
Monitor MQTT channels for trigger commands, captures high-quality images from RTSP cameras using FFmpeg, and processes them through OpenAI-compatible AI endpoints for analysis. The application supports both single and multi-image capture for advanced motion detection and temporal analysis.
MQTT Camera AI Monitor
Overview
The MQTT Camera AI Monitor is a TypeScript/Node.js application that monitors MQTT channels for trigger commands, captures high-quality images from RTSP cameras using FFmpeg, and processes them through OpenAI-compatible AI endpoints for analysis. The application supports both single and multi-image capture for advanced motion detection and temporal analysis.
Features
  • MQTT Integration: Monitors MQTT channels for trigger commands with automatic reconnection
  • RTSP Camera Support: Captures high-quality images from RTSP camera streams using FFmpeg
  • Multi-Image Capture: Sequential image capture with configurable intervals for motion analysis
  • AI Processing: Sends captured images to OpenAI-compatible endpoints for analysis
  • Binary Image Publishing: Publishes captured images as binary data to MQTT topics
  • Real-time Status Tracking: Live status updates during processing (e.g., "Taking snapshot 2/4")
  • Comprehensive Statistics: Detailed performance metrics and error tracking per camera
  • Status Monitoring: Publishes online/offline status via Last Will and Testament
  • Automatic Cleanup: Removes temporary image files to prevent disk space issues
  • Graceful Shutdown: Properly handles shutdown signals and cleanup
  • Docker Support: Runs in containerized environments with configurable file paths
  • Comprehensive Logging: Detailed logging with configurable levels for monitoring and debugging
  • Structured Output: Optional JSON schema-based responses for consistent data format
How it Works
MQTT Topic Structure
The application uses the following topic structure: <basetopic>/<cameraname>/<topicname>
Status Topics
  • <basetopic>/online - Application status ("YES" when running, "NO" when offline)
Camera Topics (for each configured camera)
  • <basetopic>/<camera>/trigger - Trigger topic (set to "YES" to start analysis, automatically resets to "NO")
  • <basetopic>/<camera>/image - Binary image data (JPEG format, retained) - First captured image
  • <basetopic>/<camera>/ai - AI analysis response (text or JSON, retained)
  • <basetopic>/<camera>/status - Current processing status (text, retained)
  • <basetopic>/<camera>/stats - Performance statistics and error tracking (JSON, retained)
Camera Status Values
The /status topic provides real-time updates during processing:
  • "Idle" - Camera ready for triggers
  • "Starting image capture" - Beginning capture process
  • "Taking snapshot" - Single image capture in progress
  • "Taking snapshot X/Y" - Multi-image capture progress (e.g., "Taking snapshot 2/4")
  • "Waiting for next capture (X/Y)" - Interval delay between captures
  • "Publishing image" - Uploading image to MQTT
  • "Processing with AI" - Sending to AI service for analysis
  • "Publishing AI response" - Uploading AI results to MQTT
  • "Cleaning up" - Removing temporary files
  • "Complete" - Successfully finished processing
  • "Error" - Error occurred during processing
  • "Offline" - Service shutting down
Camera Statistics
The /stats topic publishes a JSON object with performance metrics:
    "lastErrorDate": "2023-01-01T12:00:00.000Z",
    "lastErrorType": "Connection timeout",
    "lastSuccessDate": "2023-01-01T12:05:00.000Z",
    "lastAiProcessTime": 2.5,
    "lastTotalProcessTime": 8.2
Statistics Properties:
  • lastErrorDate - ISO timestamp of most recent error
  • lastErrorType - Description of the last error that occurred
  • lastSuccessDate - ISO timestamp of most recent successful processing
  • lastAiProcessTime - Time in seconds for AI processing only
  • lastTotalProcessTime - Total time in seconds from trigger to completion
Workflow
  1. Initialization: Application connects to MQTT broker and initializes camera topics
  2. Trigger: Set <basetopic>/<camera>/trigger to "YES" to start analysis
  3. Status Updates: Real-time status published to <basetopic>/<camera>/status
  4. Image Capture: Application captures one or multiple high-quality images from RTSP camera
  5. Image Publishing: Binary data of the first captured image is published to <basetopic>/<camera>/image
  6. AI Processing: All captured images are sent to AI endpoint with configured prompt
  7. Result Publishing: AI response is published to <basetopic>/<camera>/ai
  8. Statistics Update: Performance metrics published to <basetopic>/<camera>/stats
  9. Reset: Trigger topic is automatically reset to "NO"
  10. Cleanup: All temporary image files are automatically deleted
Multi-Image Capture
The application supports capturing multiple sequential images to provide AI with temporal context for motion detection and analysis:
  • Single Image Mode (default): Traditional single snapshot capture
  • Multi-Image Mode: Capture 2-10+ sequential images with configurable intervals
  • AI Context: Multiple images are sent in chronological order with enhanced prompts
  • Motion Analysis: AI can detect movement, direction, and changes across the sequence
  • Progress Tracking: Status updates show capture progress (e.g., "Taking snapshot 3/5")
Installation & Setup
Prerequisites
  • Node.js 18+ (for bare metal installation)
  • FFmpeg (for camera image capture)
  • MQTT broker
  • OpenAI-compatible API endpoint with vision support
Camera Configuration Options
Create a config.yaml file based on the provided config.yaml.sample.
Basic Settings
  • endpoint (required): RTSP stream URL with authentication
  • prompt (required): Text prompt for AI analysis
Multi-Image Settings
  • captures (optional): Number of images to capture (default: 1, range: 1-10+)
  • interval (optional): Milliseconds between captures (default: 1000, minimum: 0)
Advanced Settings
  • output (optional): Structured output schema for consistent JSON responses
Configuration Examples
Minimal Single Image
simple_camera:
  endpoint: rtsp://user:pass@camera/stream
  prompt: "What do you see?"
Motion Detection with Multiple Images
motion_camera:
  captures: 4
  interval: 2000
  prompt: "Detect and analyze movement across these 4 sequential images."
Structured Output with Multiple Images
security_camera:
  captures: 3
  interval: 5000
  prompt: "Analyze security footage for people and vehicle activity."
  output:
    PeopleDetected:
      type: string
      enum: ["Yes", "No", "Unknown"]
    VehicleMovement:
      type: string
      enum: ["Entering", "Leaving", "None", "Unknown"]
Deployment Options
Bare Metal
  1. Install dependencies:
    npm install
  2. Place your config file:
    cp config.yaml.sample config.yaml
    # Edit config.yaml with your settings
  3. Run the application:
    npm start
    # With debug logging
    LOG_LEVEL=debug npm start
Docker
Using Pre-built Image
docker run -d \
  --name mqtt-camera-monitor \
  -v /path/to/your/config.yaml:/usr/src/app/config.yaml \
  kosdk/mqtt-camera-ai-monitor:latest
Using Custom Config Location (Docker)
docker run -d \
  -e CONFIG_FILE=/app/config/custom-config.yaml \
  -e LOG_LEVEL=debug \
  -v /path/to/your/config.yaml:/app/config/custom-config.yaml \
Docker Compose Example
version: '3.8'
services:
  mqtt-camera-monitor:
    image: kosdk/mqtt-camera-ai-monitor:latest
    container_name: mqtt-camera-monitor
    environment:
      - CONFIG_FILE=/app/config/config.yaml
      - LOG_LEVEL=info
    volumes:
      - ./config.yaml:/app/config/config.yaml
    restart: unless-stopped
Usage Examples
Basic Single Image Analysis
# Trigger analysis
mosquitto_pub -h mqtt-server -t "mqttcaim/garage/trigger" -m "YES"
# Monitor results and status
mosquitto_sub -h mqtt-server -t "mqttcaim/garage/#"
Multi-Image Motion Detection
# Trigger 5-image sequence analysis
mosquitto_pub -h mqtt-server -t "mqttcaim/driveway/trigger" -m "YES"
# The system will:
# 1. Capture 5 images over 15 seconds (3s intervals)
# 2. Send all images to AI for motion analysis
# 3. Publish results to mqttcaim/driveway/ai
Monitoring Camera Status and Statistics
# Watch real-time status updates
mosquitto_sub -h mqtt-server -t "mqttcaim/driveway/status"
# Monitor performance statistics
mosquitto_sub -h mqtt-server -t "mqttcaim/driveway/stats"
# Check if application is online
mosquitto_sub -h mqtt-server -t "mqttcaim/online"
# Monitor all activity for a camera
mosquitto_sub -h mqtt-server -t "mqttcaim/driveway/#"
# Monitor everything
mosquitto_sub -h mqtt-server -t "mqttcaim/#"
Multi-Image Capture Benefits
Motion Detection
  • Direction Analysis: Detect people/vehicles entering or leaving
  • Speed Estimation: Understand movement speed across frames
  • Path Tracking: Follow object movement through the scene
Context Understanding
  • Activity Patterns: Understand what happened over time
  • Change Detection: Identify what changed between frames
  • Event Sequencing: Understand the order of events
Use Cases
  • Security Monitoring: Detect intrusions with movement context
  • Traffic Analysis: Monitor vehicle flow and parking changes
  • Wildlife Observation: Track animal behavior over time
  • Package Delivery: Detect delivery events with full context
Monitoring & Troubleshooting
Environment Variables
  • LOG_LEVEL: Controls logging verbosity
    • error: Only errors
    • warn: Warnings and errors
    • info: Info, warnings, and errors (default)
    • debug: Debug, info, warnings, and errors
    • verbose: Very detailed logging
    • silly: Everything
  • CONFIG_FILE: Custom config file path (Docker only)
Log Files
  • Console output: Real-time application logs
  • error.log: Error-level logs only
  • combined.log: All log levels
Performance Monitoring
Use the /stats topic to monitor camera performance:
# Get current stats for a camera
mosquitto_sub -h mqtt-server -t "mqttcaim/camera1/stats" -C 1
# Example output:
  "lastSuccessDate": "2023-10-15T14:30:25.123Z",
  "lastAiProcessTime": 3.2,
  "lastTotalProcessTime": 12.8
Common Issues
  • MQTT Connection: Check server address, credentials, and network connectivity
  • Camera Access: Verify RTSP URLs and camera credentials
  • AI API: Confirm endpoint URL, API token, and model supports vision
  • Multi-Image Timeouts: Increase AI timeout for multiple image processing
  • Disk Space: Ensure adequate space for temporary image files
  • Memory Usage: Multiple large images may require more RAM
Performance Considerations
  • Capture Duration: Total time = (captures - 1) × interval
  • AI Processing Time: Increases with number of images
  • Network Bandwidth: Multiple images require more upload bandwidth
  • Storage: Temporary files are automatically cleaned up
Configuration Reference
MQTT Settings
  • server: MQTT broker hostname/IP
  • port: MQTT broker port (typically 1883)
  • basetopic: Base topic for all MQTT communications
  • user/password: MQTT authentication credentials
  • client: MQTT client identifier
OpenAI Settings
  • endpoint: AI API endpoint URL
  • api_token: API authentication token
  • model: AI model name (must support vision/image input)
Camera Settings
  • endpoint: RTSP stream URL with credentials
  • prompt: Text prompt for AI analysis
  • captures: Number of sequential images (1-10+, default: 1)
  • interval: Milliseconds between captures (≥0, default: 1000)
  • output: Optional structured output schema
Refer to Structured model outputs - OpenAI API for more information about the output schema.
Multi-Image Guidelines
  • Optimal Captures: 3-5 images for most motion detection scenarios
  • Interval Timing: 1-5 seconds depending on expected motion speed
  • Total Duration: Keep under 30 seconds to avoid timeout issues
  • Prompt Design: Include context about sequential analysis in prompts
Contributing
Contributions are welcome! Please:
  1. Fork the repository
  2. Create a feature branch
  3. Make your changes with appropriate tests
  4. Submit a pull request
License
This project is licensed under the BSD 3-Clause License. See the LICENSE file for details.
Support
For issues and questions:
  • Check the application logs for error details
  • Monitor camera /status and /stats topics for real-time information
  • Verify configuration settings
  • Ensure network connectivity to MQTT broker and AI endpoint
  • Test with single image before using multi-image capture
  • Monitor disk space and memory usage for multi-image scenarios
  • Open an issue on the project repository
AI Notice
Vibe-coded in Claude Sonnet 4. No cap.
Categories
Download Statistics
2,418
Total Downloads
Links
Details
Repository
Last Updated2025-09-15
First Seen2025-11-01
Runtime arguments
Network
bridge
Privileged
false
Template configuration
Config FilePath
Path to the configuration file
Target
Default
/mnt/user/appdata/mqtt_camera_ai_monitor/config.yaml
Value
Log LevelVariable
Set the logging level for the application
Target
LOG_LEVEL
Default
info|error|warn|debug|verbose|silly
Internal Config LocationVariable
Internal path to the configuration file. Not recommended to change.
Target
CONFIG_FILE
Default
Value
