immich-power-tools
immich-power-tools
Docker app from campu0999's Repository
Overview
A unofficial immich client to provide better tools to organize and manage your immich account. Built to speed up your workflows in Immich to organize your people and albums.
Logo Immich Power Tools
A unofficial immich client to provide better tools to organize and manage your immich account. Building it to speed up your workflows in Immich to organize your people and albums.
[!IMPORTANT] Immich v3.0 compatibility: Power Tools v0.22.0 and above require Immich 3.0 or newer.
Watch Demo Video here
Immich Power Tools
๐ŸŽ’Features
  • Manage people data in bulk ๐Ÿ‘ซ: Options to update people data in bulk, and with advance filters
  • People Merge Suggestion ๐ŸŽญ: Option to bulk merge people with suggested faces based on similarity.
  • Update Missing Locations ๐Ÿ“: Find assets in your library those are without location and update them with the location of the asset.
  • Potential Albums ๐Ÿ–ผ๏ธ: Find albums that are potential to be created based on the assets and people in your library.
  • Analytics ๐Ÿ“ˆ: Get analytics on your library like assets over time, exif data, etc.
  • Smart Search ๐Ÿ”Ž: Search your library with natural language, supports queries like "show me all my photos from 2024 of "
  • Bulk Date Offset ๐Ÿ“…: Offset the date of selected assets by a given amount of time. Majorly used to fix the date of assets that are out of sync with the actual date.
Support me ๐Ÿ™
If you find this tool useful, please consider supporting me by buying me a coffee.
Buy me a coffee
๐Ÿ’ญ Back story
Recently I've migrated my entire Google photos library to Immich, I was able to successfully migrate all my assets along with its albums to immich. But there were few things like people match that was lacking. I loved Immich UI on the whole but for organizing content I felt its quite restricted and I had to do a lot of things in bulk instead of opening each asset and doing it. Hence I built this tool (continuing to itereate) to make my life and any other Immich user's life easier.
๐Ÿš€ Getting Started
๐Ÿฌ Using Docker
Power-tools is designed to be used alongside Immich, and there are two ways you can run it.
Method 1 - Docker Compose ( Recommended )
Add the following into your docker compose as a new service along side other immich services. Make sure you've power-tools in same network as immich.
See the sample docker-compose-all-immich.yml file for reference.
services:
  # Other services...
  power-tools:
    container_name: immich_power_tools
    image: ghcr.io/immich-power-tools/immich-power-tools:latest
    volumes:
      - immich-power-tools-data:/app/data
    ports:
      - "8001:3000"
    env_file:
      - .env
volumes:
Add the Immich API Key and immich url's to the env file (which you already have for the immich). You also need to add DB_PORT (Default 5432) and DB_HOST, which has to be set to the name of the immich database container (Default immich_postgres).
IMMICH_API_KEY= # your_immich_api_key
IMMICH_URL = "http://local-ip-of-immich:port" # Your immich instace ip address and port
EXTERNAL_IMMICH_URL = "https://external-address" # External address of immich
DB_PORT = "5432"
DB_HOST = "immich_postgres"
# Optional - AI Configuration for Smart Search (Find)
AI_API_KEY=your_api_key_here # API key for your OpenAI-compatible provider
AI_BASE_URL="https://api.openai.com/v1" # e.g. https://api.openai.com/v1 (OpenAI), https://api.groq.com/openai/v1 (Groq), http://host.docker.internal:11434/v1 (Ollama)
AI_MODEL="gpt-4o-mini" # e.g. gpt-4o-mini, llama-3.1-8b-instant, llama3.1
Refer here for obtaining Immich API Key: https://immich.app/docs/features/command-line-interface#obtain-the-api-key
[!NOTE] When creating the API key, make sure you select all the permissions for the API key.
Method 2 - Portainer
If you're using portainer, run the docker using docker run and add the power tools to the same network as immich.
# Run the power tools from docker
docker run -d --name immich_power_tools -p 8001:3000 -v immich-power-tools-data:/app/data --env-file .env ghcr.io/immich-power-tools/immich-power-tools:latest
# Add Power tools to the same network as immich
docker network connect immich_default immich_power_tools
๐Ÿš€ For local development
[!NOTE]
Please use bun to run the project. If you don't have bun installed, checkout bun.sh for installation.
Copy paste the .env.example to .env and fill in the values.
  IMMICH_URL="" # Immich URL
  IMMICH_API_KEY="" # Immich API Key
  DB_USERNAME="" # Postgress Database Username
  DB_PASSWORD = "" # Postgres Database Password
  DB_HOST = "" # Postgres Host (IP address or hostname of the database)
  DB_PORT = "" # Postgres Port number (Default: 5432)
  DB_DATABASE_NAME="" # Name of the database
  AI_API_KEY="" # API key for your OpenAI-compatible provider
  AI_BASE_URL="https://api.openai.com/v1" # Base URL for OpenAI-compatible API
  AI_MODEL="gpt-4o-mini" # Model used for parsing search queries in "Find"
[!NOTE]
Make sure you have postgres port exposed on you machine.
Run the development server:
bun run dev
Features
Immich Related
  • Manage People
    • Smart Merge
  • Manage Albums
    • Bulk Delete
    • Bulk Share
    • Bulk Edit
    • Filters
    • Potential Albums
    • People in Album
  • Missing Location
  • Statistics
    • EXIF Data
    • Assets Overtime Chart
Tech Related
  • Dark Mode
  • Dockerize
  • Authentication
  • Push to github packages
Tech Stack
External Services
These services are completely optional and you can use the tool without them. Just that they are used for some of the features. But we dont send any personal data to these services.
  • Google Maps for heatmap Google Maps Javascript API Key is used to render the maps layer for heatmap. When rendering the heatmap, we only send the location data to Google Maps and not any other data.
    Code where heatmap data is plotted: src/pages/assets/geo-heatmap.tsx:32
  • OpenAI-compatible AI provider for smart query parsing in Find Any OpenAI-compatible API can be used for parsing your search query in the "Find" page. You can use standard providers like OpenAI and Groq, or run local models using Ollama or LM Studio. We do not send any personal library data to the AI provider; only your search text is sent for parsing. The actual asset querying uses Immich's Smart Search API.
    Code where AI parsing is used: src/helpers/ai.helper.ts
    Examples:
    • OpenAI: AI_BASE_URL=https://api.openai.com/v1, AI_MODEL=gpt-4o-mini
    • Groq: AI_BASE_URL=https://api.groq.com/openai/v1, AI_MODEL=llama-3.1-8b-instant
    • Ollama (local): AI_BASE_URL=http://localhost:11434/v1 (or http://host.docker.internal:11434/v1 if running Power Tools in Docker), AI_MODEL=llama3.1
Contributing
Feel free to contribute to this project, I'm open to any suggestions and improvements. Please read the CONTRIBUTING.md for more details.
Related apps
Details
Repository
ghcr.io/varun-raj/immich-power-tools
Last Updated2026-11-13
First Seen2024-08-28
Runtime arguments
Web UI
http://[IP]:[PORT:3000]
Network
bridge
Shell
sh
Privileged
false
Template configuration
WebUIPorttcp
WebUI Port
Target
3000
Default
8001
Value
8001
IMMICH_URLVariable
Immich URL If using local ip do not include trailing /
IMMICH_API_KEYVariable
Immich API Key https://immich.app/docs/features/command-line-interface/#obtain-the-api-key
DB_USERNAMEVariable
DB_PASSWORDVariable
DB_HOSTVariable
DB_PORTVariable
DB_DATABASE_NAMEVariable
GEMINI_API_KEYVariable
Optional: For rewind video generation
GOOGLE_MAPS_API_KEYVariable
Optional: Google Maps Javascript API Key is used for heatmap
