HDHomeRun-Signal-Web
Docker app from Pete L's Repository
A modern web application that replaces the discontinued HDHomeRun Signal Android app.
Overview
A modern web application that replaces the discontinued HDHomeRun Signal Android app. This web app provides real-time signal monitoring, channel tuning, and device management for HDHomeRun devices.
Features:
  • Device Discovery: Automatically finds HDHomeRun devices on your network
  • Real-time Signal Monitoring: Live updates of signal strength, SNR quality, and symbol quality with dBm/dB estimates
  • Antenna Tuning Mode: Monitor all tuners simultaneously with real-time graphs for optimal antenna positioning
  • Direct Channel Tuning: Quickly tune to specific channels with channel up/down controls
  • Multi-tuner Support: Switch between tuners on devices that support multiple tuners
  • ATSC 3.0 Support: Displays PLP and L1 information for NextGen TV broadcasts
  • Program Detection: Automatically shows available programs/PIDs on tuned channels
  • Progressive Web App: Install on mobile devices for a native app experience
  • Responsive Design: Works on both desktop and mobile devices
  • Modern UI: Clean, dark theme interface with Material-UI components
Categories
Download Statistics
28,007
Total Downloads
4,280
This Month
3,955
Avg / Month
Total Downloads Over Time
Loading chart...
Related apps
Explore more like this
Explore all
Links
Details
Repository
petelombardo/hdhomerun-signal-web
Last Updated2026-09-22
First Seen2026-02-12
Runtime arguments
Web UI
http://[IP]:[PORT:3000]
Network
bridge
Shell
sh
Privileged
false
Template configuration
Web UI PortPorttcp
Port for the web interface
Target
3000
Default
3000
Value
3000
Container PortVariable
Internal port the app listens on (should match the Web UI Port container port)
Target
PORT
Default
3000
Value
3000
HDHomeRun DevicesVariable
Manually specify HDHomeRun devices by IP or hostname (comma-separated). Leave blank for auto-discovery.
Target
HDHOMERUN_DEVICES
Disable Auto-DiscoveryVariable
Set to 'true' to disable auto-discovery and only use manually specified devices
Target
HDHOMERUN_DISABLE_DISCOVERY
Default
false
Value
false
