blade-of-agony
blade-of-agony
Docker app from linuxserver's Repository
Wolfenstein: Blade of Agony(https://boa.realm667.com/) is a story-driven WWII shooter inspired by Wolfenstein and Doom.
Requirements
        This image is unprotected by default __**do not**__ expose it to the internet.
        Please read https://github.com/linuxserver/docker-blade-of-agony#security for more information.
Overview
linuxserver.io
Blog Discord Discussions GitHub Open Collective
The LinuxServer.io team brings you another container release featuring:
  • regular and timely application updates
  • easy user mappings (PGID, PUID)
  • custom base image with s6 overlay
  • weekly base OS updates with common layers across the entire LinuxServer.io ecosystem to minimise space usage, down time and bandwidth
  • regular security updates
Find us at:
  • Blog - all the things you can do with our containers including How-To guides, opinions and much more!
  • Discord - realtime support / chat with the community and the team.
  • Discussions - post on our community forum.
  • GitHub - view the source for all of our repositories.
  • Open Collective - please consider helping us by either donating or contributing to our budget
linuxserver/blade-of-agony
Scarf.io pulls GitHub Stars GitHub Release GitHub Package Repository GitLab Container Registry Quay.io Docker Pulls Docker Stars Jenkins Build LSIO CI
Wolfenstein: Blade of Agony is a story-driven WWII shooter inspired by Wolfenstein and Doom.
blade-of-agony
Supported Architectures
We utilise the docker manifest for multi-platform awareness. More information is available from docker here and our announcement here.
Simply pulling lscr.io/linuxserver/blade-of-agony:latest should retrieve the correct image for your arch, but you can also pull specific arch images via tags.
The architectures supported by this image are:
Architecture Available Tag
x86-64 ✅ amd64-<version tag>
arm64 ❌
Application Setup
The application can be accessed at:
To play this you will need to use a GPU!
Gaming mode
An absolute must for mouse and keyboard input is sending relative mouse input from the browser, you will need to use the "Gaming Mode" which is a small crosshair in the top right of the sidebar. This runs in fullscreen and traps you in the window, to exit this mode hold down escape for 3 seconds.
Strict reverse proxies
This image uses a self-signed certificate by default. This naturally means the scheme is https. If you are using a reverse proxy which validates certificates, you need to disable this check for the container.
This container is based on Docker Baseimage Selkies, which streams a desktop or single application to your web browser. Only the essentials are covered below, the full platform documentation lives at docs.linuxserver.io/selkies.
Start Minimal
Most support issues we see stem from large run configurations assembled from years of forum posts. These containers are designed to work with almost nothing. Start with the minimal command below, confirm it works, then add your options (volumes, env vars, GPU flags) one at a time:
docker run --rm -it \
  --shm-size=1gb \
  -p 3001:3001 \
  lscr.io/linuxserver/blade-of-agony:latest bash
Open https://localhost:3001 (note the https) and accept the self signed certificate warning. The trailing bash gives you a shell inside the container, ctrl+d exits and cleans everything up. If a bigger setup misbehaves, return to this command to isolate the problem, see the Quickstart and Troubleshooting guides.
GPU Acceleration
A GPU is optional, the CPU pipeline is fast enough for smooth sessions on modest hardware. When a GPU is mounted into the container it is automatically detected and configured for zero copy rendering and encoding, set AUTO_GPU=false to disable this behavior.
Intel / AMD (open source drivers), one flag is all it takes:
  --shm-size=1gb \
  -p 3001:3001 \
  --device /dev/dri \
Nvidia (proprietary drivers, not available on Alpine based images):
Requires host driver 580 or newer installed from the .run file downloaded directly from Nvidia. On drivers older than 595.80 you may also need kernel parameters and a dummy plug, see GPU Acceleration before opening an issue.
  --shm-size=1gb \
  -p 3001:3001 \
  --runtime nvidia \
  --gpus all \
  --device /dev/nvidia-modeset \
Compose examples, multi GPU selection (DRINODE/DRI_NODE), Unraid notes, and a step by step debugging loop are in the GPU Acceleration guide.
Security
[!WARNING] This container provides privileged access to the host system. Do not expose it to the Internet unless you have secured it properly.
HTTPS is required. Modern browser features used for video and audio (WebCodecs) only work in a secure context. Port 3001 serves HTTPS directly, the HTTP port exists only to sit behind a reverse proxy.
By default there is no authentication. Setting the CUSTOM_USER and PASSWORD environment variables enables HTTP basic auth, which is suitable only for a trusted local network. For internet exposure, place the container behind a reverse proxy with robust authentication, such as SWAG. Keep in mind the web interface includes a terminal with passwordless sudo, anyone who can reach the GUI can gain root inside the container.
Authentication options, sharing link behavior, container isolation, and the lockdown variables for kiosk style deployments are covered in Security and Hardening.
Language Support - Internationalization
To launch the session in a different language, set the LC_ALL environment variable, e.g. -e LC_ALL=zh_CN.UTF-8 (Chinese), ja_JP.UTF-8 (Japanese), ko_KR.UTF-8 (Korean), ar_AE.UTF-8 (Arabic), ru_RU.UTF-8 (Russian), es_MX.UTF-8 (Spanish Latin America), de_DE.UTF-8 (German), fr_FR.UTF-8 (French), nl_NL.UTF-8 (Dutch), it_IT.UTF-8 (Italian).
Beyond Running the App
This image inherits every capability of the Selkies platform, all documented in depth on the docs site:
  • Configuration Reference - every environment variable: ports, subfolder reverse proxy, custom dashboards, watermarking, and the full set of SELKIES_* stream, feature, and UI settings with their |locked syntax.
  • Using the Web Client - file transfer, clipboard sync, audio and microphone, up to four gamepads, session sharing, and mobile touch support.
  • Installing Applications - persistent user installed apps with proot-apps (proot-apps install filezilla) or native packages at boot with Docker mods.
  • Docker in Docker and host Docker control - run --privileged for an isolated DinD setup, or mount /var/run/docker.sock to manage the host.
  • Reverse Proxy - proxying websockets and subfolders correctly.
  • SealSkin - turnkey multi user VDI orchestration with browser extension and mobile apps, this image is fully compatible.
  • Pelorus - expose the session to AI agents via a computer use API and accessibility stack.
Usage
To help you get started creating a container from this image you can either use docker-compose or the docker cli.
[!NOTE] Unless a parameter is flagged as 'optional', it is mandatory and a value must be provided.
docker-compose (recommended, click here for more info)
services:
  blade-of-agony:
    image: lscr.io/linuxserver/blade-of-agony:latest
    container_name: blade-of-agony
    environment:
      - PUID=1000
      - PGID=1000
      - TZ=Etc/UTC
    volumes:
      - /path/to/config:/config
    ports:
      - 3000:3000
      - 3001:3001
    shm_size: "1gb"
    restart: unless-stopped
docker cli (click here for more info)
docker run -d \
  --name=blade-of-agony \
  -e PUID=1000 \
  -e PGID=1000 \
  -e TZ=Etc/UTC \
  -p 3000:3000 \
  -p 3001:3001 \
  -v /path/to/config:/config \
  --shm-size="1gb" \
  --restart unless-stopped \
Parameters
Containers are configured using parameters passed at runtime (such as those above). These parameters are separated by a colon and indicate <external>:<internal> respectively. For example, -p 8080:80 would expose port 80 from inside the container to be accessible from the host's IP on port 8080 outside the container.
Parameter Function
-p 3000:3000 HTTP Blade of Agony desktop gui must be proxied.
-p 3001:3001 HTTPS Blade of Agony desktop gui.
-e PUID=1000 for UserID - see below for explanation
-e PGID=1000 for GroupID - see below for explanation
-e TZ=Etc/UTC specify a timezone to use, see this list.
-v /config Users home directory in the container, stores local files and settings
--shm-size= This is needed for Blade of Agony to function.
Environment variables from files (Docker secrets)
You can set any environment variable from a file by using a special prepend FILE__.
As an example:
-e FILE__MYVAR=/run/secrets/mysecretvariable
Will set the environment variable MYVAR based on the contents of the /run/secrets/mysecretvariable file.
Umask for running applications
For all of our images we provide the ability to override the default umask settings for services started within the containers using the optional -e UMASK=022 setting. Keep in mind umask is not chmod it subtracts from permissions based on it's value it does not add. Please read up here before asking for support.
User / Group Identifiers
When using volumes (-v flags), permissions issues can arise between the host OS and the container, we avoid this issue by allowing you to specify the user PUID and group PGID.
Ensure any volume directories on the host are owned by the same user you specify and any permissions issues will vanish like magic.
In this instance PUID=1000 and PGID=1000, to find yours use id your_user as below:
id your_user
Example output:
uid=1000(your_user) gid=1000(your_user) groups=1000(your_user)
Docker Mods
Docker Mods Docker Universal Mods
We publish various Docker Mods to enable additional functionality within the containers. The list of Mods available for this image (if any) as well as universal mods that can be applied to any one of our images can be accessed via the dynamic badges above.
Support Info
  • Shell access whilst the container is running:
    docker exec -it blade-of-agony /bin/bash
  • To monitor the logs of the container in realtime:
    docker logs -f blade-of-agony
  • Container version number:
    docker inspect -f '{{ index .Config.Labels "build_version" }}' blade-of-agony
  • Image version number:
    docker inspect -f '{{ index .Config.Labels "build_version" }}' lscr.io/linuxserver/blade-of-agony:latest
Updating Info
Most of our images are static, versioned, and require an image update and container recreation to update the app inside. With some exceptions (noted in the relevant readme.md), we do not recommend or support updating apps inside the container. Please consult the Application Setup section above to see if it is recommended for the image.
Below are the instructions for updating containers:
Via Docker Compose
  • Update images:
    • All images:
      docker-compose pull
    • Single image:
      docker-compose pull blade-of-agony
  • Update containers:
    • All containers:
      docker-compose up -d
    • Single container:
      docker-compose up -d blade-of-agony
  • You can also remove the old dangling images:
    docker image prune
Via Docker Run
  • Update the image:
    docker pull lscr.io/linuxserver/blade-of-agony:latest
  • Stop the running container:
    docker stop blade-of-agony
  • Delete the container:
    docker rm blade-of-agony
  • Recreate a new container with the same docker run parameters as instructed above (if mapped correctly to a host folder, your /config folder and settings will be preserved)
    docker image prune
Image Update Notifications - Diun (Docker Image Update Notifier)
[!TIP] We recommend Diun for update notifications. Other tools that automatically update containers unattended are not recommended or supported.
Building locally
If you want to make local modifications to these images for development purposes or just to customize the logic:
git clone https://github.com/linuxserver/docker-blade-of-agony.git
cd docker-blade-of-agony
docker build \
  --no-cache \
  --pull \
  -t lscr.io/linuxserver/blade-of-agony:latest .
The ARM variants can be built on x86_64 hardware and vice versa using lscr.io/linuxserver/qemu-static
docker run --rm --privileged lscr.io/linuxserver/qemu-static --reset
Once registered you can define the dockerfile to use with -f Dockerfile.aarch64.
Versions
  • 26.03.26: - Initial release.
Download Statistics
12,800
Total Downloads
Links
Details
Repository
Last Updated2026-10-22
First Seen2026-04-13
Runtime arguments
Web UI
https://[IP]:[PORT:3001]
Network
bridge
Shell
bash
Privileged
false
Extra Params
--shm-size=1gb
Template configuration
WebUIPorttcp
Target
3000
Default
3000
Port: 3001Porttcp
Target
3001
Default
3001
AppdataPathrw
Target
/config
PUIDVariable
Container Variable: PUID
Default
99
PGIDVariable
Container Variable: PGID
Default
100
UMASKVariable
Container Variable: UMASK
Default
022
