Authelia-Admin-Control-Panel
Docker app from grtgbln's Repository
A web-based administration interface for managing Authelia authentication server with LLDAP.
Requirements
        Requires a `config.yaml` file to be present in the Config Path. See documentation: https://github.com/asalimonov/authelia-admin#yaml-configuration
Overview
Authelia Admin Control Panel
Features
  • Management of users and groups in LLDAP
  • View and manage TOTP configurations
  • View TOTP history
  • Management of banned users and IPs
  • Dedicated role for management of regular users (user_manager)
  • Dedicated role for management of passwords of regular users (password_manager)
  • Internationalization
  • Ability to add another directory system
Not yet implemented
  • Management of attributes of users and groups
  • Browsing and management of users in Authelia file provider
How to run locally with PostgreSQL
  • checkout the repository
  • /etc/hosts entries: 127.0.0.1 localhost.test auth.localhost.test ldap.localhost.test
  • Run in the first termainl: docker-compose -f docker-compose.test-pg.yml up
  • Run in the second terminal: sleep 5 && docker compose -f docker-compose.test-pg.yml exec -T lldap /bootstrap/bootstrap.sh
  • Close the second terminal
  • Open https://auth.localhost.test and login, then go to https://auth.localhost.test/auth-admin
Configuration
Configuration can be provided via YAML file or environment variables. Environment variables specific to the application use the AAD_ prefix and override YAML values.
Don't forget to configure your load balancer. Authelia Admin CP should be accessible at https://{{AAD_AUTHELIA_DOMAIN}}/auth-admin/.
Authelia Admin implements concept of protected users. Protected users are users which belong to the following groups: lldap_admin, lldap_password_manager, lldap_strict_readonly, authelia_user_manager. Only users with membership in lldap_admin can do anything with other protected users. Protected users are implemented to prevent access rights escalation.
Add your users of Authelia Admin in the following groups:
  • lldap_password_manager - can list users, groups and change password of not protected users
  • authelia_user_manager - lldap_password_manager access rights + can create, edit and delete users, can change memeberhip and password of non protected users
  • lldap_admin - full access rights
Environment Variables
Mandatory settings for non-development environment
You need to specify only the following environment variables for a minimal instance:
  • AAD_AUTHELIA_DOMAIN - Domain of Authelia server for authentication of requests, e.g., auth.yourdomain.com
  • TRUSTED_ORIGINS - Trusted origins for CSRF protection, e.g., https://auth.yourdomain.com
Application Configuration
Variable Description Default
PORT Server port 9093
HOST Server host 0.0.0.0
AAD_CONFIG_PATH Path to config.yml /opt/authelia-admin/config.yml
AAD_LOGLEVEL Logging level WARN
Authelia Integration
AAD_AUTHELIA_DOMAIN Authelia domain for authentication auth.localhost.test
AAD_AUTHELIA_CONFIG_PATH Path to Authelia's configuration.yml (optional when AAD_DB_* define the database) /config/configuration.yml
AAD_AUTHELIA_COOKIE_NAME Session cookie name authelia_session
AAD_AUTHELIA_MIN_AUTH_LEVEL Minimum auth level (1=password, 2=2FA) 2
AAD_AUTHELIA_ALLOWED_USERS Comma-separated list of allowed users (empty = all users)
Directory Service (LLDAP GraphQL)
AAD_DIRECTORY_TYPE Directory service type lldap-graphql
AAD_DIRECTORY_LLDAP_GRAPHQL_ENDPOINT LLDAP GraphQL API endpoint http://lldap:17170/api/graphql
AAD_DIRECTORY_LLDAP_GRAPHQL_USER LLDAP admin username admin
AAD_DIRECTORY_LLDAP_GRAPHQL_PASSWORD LLDAP admin password (required)
AAD_DIRECTORY_LLDAP_GRAPHQL_LDAP_HOST LDAP host for password changes lldap
AAD_DIRECTORY_LLDAP_GRAPHQL_LDAP_PORT LDAP port for password changes 3890
AAD_DIRECTORY_LLDAP_GRAPHQL_LDAP_BASE_DN LDAP base DN for user operations (required for password changes)
Database (Authelia storage)
Authelia Admin works with Authelia's storage database: SQLite or PostgreSQL. Settings are merged per key, from lowest to highest priority:
  1. Built-in defaults
  2. storage section of Authelia's configuration.yml (AAD_AUTHELIA_CONFIG_PATH)
  3. AAD_DB_* environment variables
The database type is AAD_DB_TYPE when set, otherwise the storage.local or storage.postgres section of the Authelia file. Values of the other backend are ignored. The Authelia file is optional when environment variables define the database.
Database configuration is validated at startup:
  • An invalid value stops the container with exit code 1. The log names the variable. Secrets are never logged.
  • Without any database configuration the application starts with a warning. Database pages show an error and /auth-admin/health returns 500.
  • Connection errors are reported per request, so the database may start after Authelia Admin.
Variable Description Default Authelia file source
AAD_DB_TYPE PG or SQLITE, case-insensitive from Authelia file storage.local / storage.postgres
AAD_DB_SQLITE_PATH Path to Authelia's SQLite database (required for SQLITE) storage.local.path
AAD_DB_SQLITE_BUSY_TIMEOUT_MS Wait time for SQLite locks, milliseconds 5000 —
AAD_DB_PG_HOST PostgreSQL host localhost host of storage.postgres.address
AAD_DB_PG_PORT PostgreSQL port 5432 port of storage.postgres.address
AAD_DB_PG_DATABASE Database name authelia storage.postgres.database
AAD_DB_PG_USERNAME User name authelia storage.postgres.username
AAD_DB_PG_PASSWORD Password (empty) storage.postgres.password
AAD_DB_PG_PASSWORD_FILE File with the password, e.g. a Docker or Kubernetes secret. Must not be combined with AAD_DB_PG_PASSWORD — —
AAD_DB_PG_SCHEMA Schema public storage.postgres.schema
AAD_DB_PG_TIMEOUT_MS Connection timeout, milliseconds (0 = no timeout) 5000 storage.postgres.timeout
AAD_DB_PG_POOL_MAX Maximum connection pool size 10 —
AAD_DB_PG_TLS_MODE disable, require, verify-ca or verify-full disable; verify-full when the file has a tls block storage.postgres.tls
AAD_DB_PG_TLS_CA_FILE PEM file with trusted CA certificates system trust store —
AAD_DB_PG_TLS_CERT_FILE PEM client certificate for mutual TLS — storage.postgres.tls.certificate_chain
AAD_DB_PG_TLS_KEY_FILE PEM client private key for mutual TLS — storage.postgres.tls.private_key
AAD_DB_PG_TLS_SERVER_NAME Name verified in the server certificate instead of the host host storage.postgres.tls.server_name
AAD_DB_PG_TLS_MIN_VERSION TLS1.2 or TLS1.3 TLS1.2 storage.postgres.tls.minimum_version
AAD_DB_PG_TLS_MAX_VERSION TLS1.2 or TLS1.3 TLS1.3 storage.postgres.tls.maximum_version
*_MS variables are plain integers of milliseconds. Authelia's timeout uses Authelia duration notation: 5s, 1m30s, or a plain integer of seconds.
PostgreSQL TLS modes:
Mode Encrypted Certificate chain verified Host name verified Authelia equivalent
disable no no no no tls block
require yes no (skip verify) no tls.skip_verify: true
verify-ca yes yes, AAD_DB_PG_TLS_CA_FILE required no —
verify-full yes yes yes tls block
TLS verification is not affected by NODE_TLS_REJECT_UNAUTHORIZED. Opportunistic TLS (prefer), Authelia servers fallbacks and unix:// addresses are not supported.
Security
TRUSTED_ORIGINS CSRF trusted origins (required for production)
NODE_TLS_REJECT_UNAUTHORIZED Set to 0 for self-signed certificates (not set)
YAML Configuration
Example of config.yml for authelia-admin:
# Logging level (DEBUG, INFO, WARN, ERROR). Default: WARN
# Can be overridden by AAD_LOGLEVEL environment variable
logging_level: WARN
authelia:
  # Domain where Authelia is accessible
  domain: auth.localhost.test
  # Name of the session cookie used by Authelia
  cookie_name: authelia_session
  # Minimum authentication level required (1=password, 2=2FA)
  min_auth_level: 2
  # Optional: List of allowed users (if not set, all authenticated users are allowed)
  # allowed_users:
  #   - admin
  #   - user2
# Directory service configuration
directory:
  # Type of directory service (currently only lldap-graphql is supported)
  type: lldap-graphql
  # Configuration for LLDAP GraphQL backend
  lldap-graphql:
    endpoint: http://lldap:17170/api/graphql
    user: admin
    password: admin1234
    ldap_host: lldap
    ldap_port: 3890
    # LDAP base DN (required for password changes)
    ldap_base_dn: dc=example,dc=com
Docker
The application runs on port 9093 and expects the Authelia database to be mounted.
docker run -p 9093:9093 \
  -v /path/to/authelia/config:/config \
  -v /path/to/authelia/data:/data \
  -v /path/to/authelia-admin/config.yml:/opt/authelia-admin/config.yml:ro \
  -e AAD_LOGLEVEL=DEBUG \
  -e TRUSTED_ORIGINS=https://auth.yourdomain.com \
  ghcr.io/asalimonov/authelia-admin:latest
Alternatively, using environment variables instead of a config file:
  -e AAD_AUTHELIA_DOMAIN=auth.yourdomain.com \
  -e AAD_DIRECTORY_LLDAP_GRAPHQL_ENDPOINT=http://lldap:17170/api/graphql \
  -e AAD_DIRECTORY_LLDAP_GRAPHQL_USER=admin \
  -e AAD_DIRECTORY_LLDAP_GRAPHQL_PASSWORD=secret \
PostgreSQL configured only with environment variables, without mounting Authelia's configuration:
  -v /path/to/secrets:/run/secrets:ro \
  -e AAD_DB_TYPE=PG \
  -e AAD_DB_PG_HOST=postgres \
  -e AAD_DB_PG_USERNAME=authelia \
  -e AAD_DB_PG_PASSWORD_FILE=/run/secrets/postgres-password \
  -e AAD_DB_PG_TLS_MODE=verify-full \
  -e AAD_DB_PG_TLS_CA_FILE=/run/secrets/postgres-ca.pem \
Note: When deploying with a reverse proxy, ensure the TRUSTED_ORIGINS matches your domain for CSRF protection.
SQLite: Authelia Admin runs as uid 1001 and opens the database read-write. The database file and its directory must be writable by uid 1001, e.g. run Authelia with PUID=1001 and PGID=1001.
Docker Compose
See docker-compose.yml for a complete example with Authelia, LLDAP, and Traefik.
Development
# Install dependencies and build docker image
make build-dev
# Run Authelia, LLDAP, and Traefik via Docker Compose
make run-docker-compose
# In a second terminal, run Docker with authelia-admin with hot-reload
make run-dev
Use admin user with admin1234 password. The confirmation code can be found in the ./test-data/authelia/notification.txt file.
E2E Test Prerequisites
  • Docker and Docker Compose installed
  • Production image built with make build
  • Chromium installed: npx playwright install chromium
Run Playwright UI - npx playwright test --config=e2e/playwright.config.ts --ui --project=chromium
Integration Tests
make test-large builds the production image and runs tests/integration with Testcontainers. The tests start LLDAP, Authelia, Traefik and PostgreSQL in throwaway containers and verify database configuration via AAD_DB_* variables for SQLite and PostgreSQL, including TLS modes and startup validation.
Prerequisites:
  • Docker
  • Node.js 22.22+ and npm install on the host. The tests run on the host, not inside a container.
  • The image under test. make test-large builds it. npm run test:integration uses authelia-admin:latest from make build, or the image in AAD_TEST_IMAGE.
Requirements
  • Node.js 22+
  • Access to Authelia's storage: the SQLite database file or the PostgreSQL server
  • Authelia's configuration file, unless the database is configured with AAD_DB_* variables
  • Access to GraphQL and LDAP interfaces of LLDAP
Media gallery
Categories
Links
Details
Repository
Last Updated2026-11-22
First Seen2025-12-28
Runtime arguments
Web UI
http://[IP]:[PORT:9093]/
Network
bridge
Privileged
false
Template configuration
Web UI PortPorttcp
Container Port: 9093
Target
9093
Default
9093
Value
9093
Authelia Config FilePathro
Path to the Authelia config.yaml file
Target
Trusted OriginsVariable
Set the trusted origins for Authelia
Target
TRUSTED_ORIGINS
Default
Config PathPath
Path to the config folder
Target
/config
Default
/mnt/user/appdata/authelia_admin/config
Value
App Data PathPath
Path to the app data folder
Target
/data
Default
/mnt/user/appdata/authelia_admin/data
Value
Log LevelVariable
Set the log level
Target
AAD_LOGLEVEL
Default
DEBUG|INFO|WARNING|ERROR|CRITICAL
