audio-transcode-watcher
Docker app from geiserx's Repository
Watches a source folder for audio files and automatically transcodes them to multiple formats (ALAC, AAC, MP3, Opus, FLAC, WAV) in parallel using FFmpeg.
Overview
Ideal for music library management — keep lossless originals and automatically generate compressed versions for mobile devices or streaming.
More info: https://github.com/GeiserX/audio-transcode-watcher
Readme
View on GitHub
A containerized service that watches a source folder and automatically transcodes audio files to multiple formats simultaneously.
Keep one library in several formats: lossless for the archive, lossy for phones and cars. Drop a FLAC into the source folder and the ALAC, MP3, AAC and Opus copies appear in their own trees.
Features
- Watches the source folder and reacts to new, changed, renamed and deleted files.
- Writes any number of outputs in one pass, in ALAC, AAC, MP3, Opus, FLAC or WAV at the bitrate you pick.
- Mirrors the Artist/Album folder tree in every output.
- Copies lossy sources (MP3, M4A, Ogg, Opus, WMA) unchanged instead of inflating them into a lossless output.
- Fails loudly on a source that does not decode cleanly, and writes no output for it.
- Keeps ReplayGain, MusicBrainz ids, ISRC, label and sort tags in ALAC and AAC copies.
- Optionally measures every file and writes ReplayGain 2.0 track gain into the source and every output, so the whole library plays at one volume.
- Fetches synced
.lrclyrics, and writes nothing when no real lyrics are found. - Embeds cover art if you want it.
- Writes atomically and removes orphaned outputs, but never deletes anything when a folder looks empty.
- Handles Unicode file names.
- Ships as a small container on Python 3.14-slim with FFmpeg.
Quick start
curl -fsSL -o config.yaml https://raw.githubusercontent.com/GeiserX/audio-transcode-watcher/main/config.example.yaml
docker run -d --name audio_transcoder -e CONFIG_FILE=/app/config.yaml \
-v ./config.yaml:/app/config.yaml:ro -v /path/to/flac:/music/flac:ro -v /path/to/mp3:/music/mp3 \
drumsergio/audio-transcoder:0.7.2
Edit config.yaml first so its outputs match the folders you mount; the example writes ALAC, MP3 and AAC. Getting started has Docker Compose and the full docker run.
Documentation
- Getting started: Docker Compose and Docker CLI
- Configuration: the full YAML example, supported codecs,
CONFIG_JSON - Usage: what happens once it runs, and the verification tool
- How it works: sync and watch mode, folder mirroring, safety guards, performance
- Development: tests, building the image, contributing
- Roadmap
- Changelog
Related projects
| Project | Description |
| slskd-transform | Bulk upgrade your music library from lossy to lossless via Soulseek |
| telegram-slskd-local-bot | Automated music discovery and download via Telegram |
| quality-gate-encoder (formerly jellyfin-encoder) | Automatic 720p HEVC, H.264 or AV1 copies for Jellyfin |
License
Categories
Download Statistics
Related apps
Explore more like this
Explore allLinks
Details
drumsergio/audio-transcoder:latestRuntime arguments
- Network
bridge- Privileged
- false
Template configuration
YAML configuration file (read-only)
- Target
- /app/config.yaml
- Default
- /mnt/user/appdata/audio-transcoder/config.yaml
Source audio folder (read-only)
- Target
- /music/flac
- Default
- /mnt/user/Multimedia/Music/FLAC
ALAC output directory
- Target
- /music/alac
- Default
- /mnt/user/Multimedia/Music/ALAC
MP3 output directory
- Target
- /music/mp3
- Default
- /mnt/user/Multimedia/Music/MP3
AAC output directory
- Target
- /music/aac
- Default
- /mnt/user/Multimedia/Music/AAC
Timezone
- Default
- America/New_York
