audio-cpp
Docker app from lozenge's Repository
audio.cpp for Unraid: community-maintained installation templates using unmodified upstream Docker images and the native WebUI/audio API.
Requirements
Overview
Readme
View on GitHubaudio.cpp for Unraid
Run audio AI models on your own Unraid server, with a browser interface for trying them and an API for connecting your own applications.
This community app installs the official, unmodified audio.cpp Docker image and enables its built-in WebUI. You do not need to compile anything or write code to get started. A model is a downloadable AI package for a particular task, such as speech generation or transcription. Choose the models you want after installation; this template does not select a model, bundle extra voices, or add custom application code.
Beta integration: basic speech generation has been tested on CPU and NVIDIA GPU setups, but public-listing installation checks are still in progress. The AMD / Intel Vulkan option has not been tested on hardware yet. See tested hardware and known limitations.
What can I use it for?
Depending on the model you choose, upstream audio.cpp can:
- Turn text into speech: create narration, spoken messages or voiceovers.
- Transcribe recordings: turn speech in an audio file into text.
- Work with existing audio: use supported models for tasks such as voice conversion or separating vocals from music.
- Generate music or sound effects: experiment with models that support those tasks.
These are upstream capabilities, not a promise that every model works on every device. Our Unraid testing so far focuses on Pocket TTS English GGUF Q8. Check upstream's supported models for each model's features and requirements. Use recordings and voices you have permission to use.
The server runs the models locally. You still need internet access to pull the Docker image and download model packages; review each model's licence before use.
Choose your hardware option
| Option | When to choose it |
| CPU | You do not have a compatible NVIDIA GPU, or want the simplest setup. Performance depends on your CPU and model. |
| NVIDIA / CUDA 12 | You have an NVIDIA GPU with a compatible driver and the Unraid NVIDIA Driver plugin installed. |
| NVIDIA / CUDA 13 | Your GPU and driver support the CUDA 13 image. Do not select it just because its version number is higher. |
| AMD / Intel — Vulkan | You have an AMD or Intel GPU and its driver is loaded on Unraid. Not for NVIDIA GPUs. Untested so far: no hardware report exists yet. |
An AMD or Intel CPU can use the CPU option if supported by the upstream image. GPU acceleration needs enough free GPU memory for your chosen model. Other containers sharing the GPU also consume that memory. Upstream calls CUDA its optimized path and Vulkan a portability backend, so some models can be slower or unsupported on Vulkan.
For image tags, driver considerations and GPU selection details, see the hardware reference.
Check that the Vulkan option uses your GPU
The Vulkan image includes a software fallback called llvmpipe that runs on
the CPU. If the container cannot reach your GPU, speech still works but slowly.
After installation, open the Unraid terminal and run:
docker exec audio-cpp /app/entrypoint.sh server --backend vulkan --list-devices
Look for a line that starts with Vulkan: and names your GPU, ending in
[gpu]. If you only see [cpu] lines, llvmpipe or No devices found,
the container cannot use the GPU. Make sure that /dev/dri exists on the host.
The Intel GPU TOP or Radeon TOP plugin loads the driver. Make sure that
the container keeps the supplied Extra Parameters. Please report the output in
GitHub Issues either way,
because this option is waiting for its first hardware report.
Install on Unraid
Before starting, have space for both the Docker image and downloaded models, and enough RAM (or GPU memory) for the model you intend to run.
- In Unraid's Apps tab, search for
audio-cppand select the entry maintained bylozenge0. If it is not visible, check the listing status; do not confuse a private test entry with the public app. - Choose CPU, CUDA 12, CUDA 13 or Vulkan. Do not switch hardware support by changing only the image tag. The GPU options also need runtime or device settings.
- Review WebUI / API port. Keep host port
6969if it is free; otherwise choose an unused host port. Leave the container port at8080. - Review Model storage. The suggested folder is
/mnt/user/appdata/audio-cpp/models. It stores downloaded models so they can survive container replacement. For a first installation, use a new dedicated folder and keep the supplied permission settings. - For NVIDIA, review NVIDIA GPU selection. The default
allexposes all NVIDIA GPUs; use a specific GPU UUID if you want to limit access to one card. For Vulkan, keep GPU device at/dev/dri. - Apply the settings, wait for the image to download and the container to start, then open WebUI from its menu on Unraid's Docker tab.
If you already run audio.cpp, use a different container name, unused host port
and separate model folder for this installation. Do not overwrite your working
setup. The 6969 default applies to new installations; existing installations
keep their configured host port.
Make your first speech sample
The WebUI includes model downloads and a Studio for trying models. Names and layout can change as upstream releases new images.
- Open the model catalog/download area and choose a text-to-speech model. Pocket TTS English GGUF Q8 is an example we have tested, not a required default. “GGUF Q8” identifies the model package/precision.
- Download it into the mounted models location,
/app/models, and wait for installation to finish. - In Studio, choose text-to-speech, select the installed model and a voice it offers, then generate a short sentence such as: “Hello, this is my first audio.cpp test.”
- Play the result. The first request may take longer while the model loads. Try a longer sentence once that works.
No model is preselected by this integration. Different models offer different voices, languages and controls. A retained download does not necessarily mean the model is automatically registered after a restart; you may need to select it again. Stable API model IDs need advanced configuration.
Use it from another application
You can also use audio.cpp as an audio-processing service for your own scripts or apps—for example, to generate spoken notifications or transcribe recordings. Those integrations are yours to configure; this template does not add them.
Use your Unraid server's address and the host port you selected. The server
provides /health for a server-health check and /v1/models to list registered
model IDs. A healthy server does not prove a model is loaded or ready to generate.
Use the registered IDs, not guessed model names, when making requests.
See the official API guide for speech generation, transcription and other endpoints. Some endpoints use OpenAI-style formats; that does not guarantee compatibility with every client.
Security
There is no login or API authentication in this setup. Anyone who can reach the port may be able to run jobs and manage models. Keep it on a trusted network; do not expose the port directly to the internet. Remote access needs separate, authenticated protection. See security guidance.
Storage and updates
Keep your model folder and any configuration backed up. The template runs as
99:100, the numeric user/group used for new model folders on the tested Unraid
host. Leave that setting in place; do not add PUID/PGID variables or broadly
change appdata permissions to fix an error.
Container updates come directly from upstream's rolling images, not only numbered releases. This template does not enable automatic updates for you. Test your setup before enabling them and retain a known-good image reference for rollback. An image update does not update your models or GPU driver.
See permissions and updates/rollback for the details.
Already installed?
Unraid does not update the template of a container that is already installed. Changes to this template apply to new installations only. The app's change log in the Apps tab lists each change. If you installed before 2026-09-13:
- The default host port changed to
6969for new installations. Your container keeps its current port. Nothing to do. - The app icon changed to a PNG so that the Docker page can show it. To get
the new icon, remove the container (your model folder stays), then install
audio-cppagain from the Apps tab with the same port and folder. If the old icon still shows, Unraid kept a cached copy at/boot/config/plugins/dockerMan/images/audio-cpp-icon.png. Delete that file and reload the Docker page. - An AMD / Intel Vulkan option was added for new installations. To move an existing CPU installation to it, install the app again from the Apps tab with the Vulkan option and the same model folder. Changing the image tag by hand does not add the device and group settings.
Need help?
- WebUI will not open: check that the container is running, its logs, and the host port you selected.
- A download fails: check free space and model-folder permissions.
- Generation fails or says “Failed to fetch”: check container logs and whether it stopped; the message alone does not identify the cause. Note the model and image version when reporting it.
- Installation/template questions: open an issue in lozenge0/audio-cpp-unraid. Remove credentials, private paths and personal text/audio from reports.
Further reading
- Configuration reference: image variants, permissions, tuning, optional JSON and rollback.
- Tested images and remaining checks: what we have and have not verified.
- Maintainer guide: project scope, CI, release process and links to detailed test reports.
- Upstream audio.cpp: model capabilities, software documentation and development.
The integration is community-maintained, not an official endorsement by audio.cpp or Unraid. Its files use the MIT licence, not the licences of upstream software or model weights. The icon is separately dedicated under CC0 1.0 to the extent the owner holds applicable rights; see artwork terms.
Categories
Related apps
Explore more like this
Explore allLinks
Details
ghcr.io/0xshug0/audio.cpp:full-cpuRuntime arguments
- Web UI
http://[IP]:[PORT:8080]/- Network
bridge- Shell
bash- Privileged
- false
- Extra Params
--user=99:100
Template configuration
Host HTTP port. Change this if another container uses it; leave the container port at 8080. No authentication is provided.
- Target
- 8080
- Default
- 6969
- Value
- 6969
Persistent model packages downloaded through the upstream WebUI. Must be writable by UID 99/GID 100, set through Docker --user in Extra Parameters. Existing folders may need a permissions review; PUID/PGID are not supported. No models are preselected or bundled.
- Target
- /app/models
- Default
- /mnt/user/appdata/audio-cpp/models
- Value
